Userguide cfclient GUI
How to get flying
  • Start up the application
  • Press Scan
  • When the handshake is done you can start flying the Crazyflie. Remember the most tricky part is the thrust so start out easy...
Main UI
CF client main
    • Address: The address to scan for. If you didn’t change this in the configuration, then leave the default of 0xE7E7E7E7E7
    • Auto Reconnect: Try to automatically reconnect when connection is lost.
    • Battery and link quality (from 0% to 100%)
    • Tabs with specific functionality (see below for details)
    • The selected and used input interface
Functionality
Firmware upgrade
For updating the Crazyflie firmware there's the possibility to enter bootloader mode and flash new firmware from within the client. The bootloader mode is accessed from the menu Crazyflie->Bootloader. If there is any problem during the flashing or a wrong firmware is flashed the process can just be started again.
CFclient bootloading
  • Go to the menu Crazyflie->Bootloader
  • For Crazyflie 2.0 hold the button for about 3 seconds when turning it on until the blue LED M2 starts to blink to get into bootloader mode. If a wrong nRF51 firmware has been flashed you might have to start from an un-powered state. Then hold the button and connect power.
  • Click "Initiate bootloader cold boot"
  • Press "Browse" and select the binary you want to download (e.g. cflie.bin). Note: A *.bin file will be flashed to the STM32xxx only. Or select a zip file containing firmware for both nRF51 and STM32F405 for Crazyflie 2.0 as well as firmware for the STM32F103 for the Crazyflie 1.0.
  • Press "Program" and wait
  • Press "Restart in firmware mode"
To check the firmware version, under the View menu, open up Tabs->Console tab and look at the output when connecting to the Crazyflie 1.0/2.0.
Firmware configuration
  • Radio channel Can be set to anything between 0 and 125, correspond to a frequency from 2400MHz to 2525MHz. In most countries channel 0 to 80 is OK to use but this should be checked with you local regulations. If using 2M datarate, the copter channels should be 2 apart (2MHz).
Crazyflie 1.0 Crazyflie 2.0
Click on the menu "Crazyflie->Configure 1.0" and then connect the bootloader by clicking on the "cold boot" button and by restarting the Crazyflie. First connect to the Crazyflie 2.0 with the normal connect button. Then open "Crazyflie->Configure 2.0" to reach the configure 2.0 dialog
CF1 config CF2 config
Logging
The Crazyflie logging framework allows to log the state of Crazyflie variables in real-time. This subsystem is used by the client to show information like pose or battery level.
The list of log variable can be seen in the "log TOC" tab in the client.
Variables are logged in block: one log block is a list of variable that are logged at the same time. You can setup custom log blocks that can be plotted in the plotter and saved to file in the log block tab.
To setup a new log block click on the menu "settings/logging configuration", You then see the following toolbox:
cfclient logging configuration
  1. List of log variable in the Crazyflie
  2. Log variables in the current log block
  3. Add the selected Crazyflie log variable in the log block
  4. Remove the selected log block variable from the log block
  5. Period at which the variables are sampled and the block is send by the Crazyflie to the client. The minimum possible period is 10ms (100Hz) and it can be set by step of 10ms up to 2550ms.
  6. Space taken by the variables in the log block.
  7. Name of the new or existing log blocks. You can choose an existing block from the list or type the name of a new one
  8. Load existing log block configuration
  9. Save log block configuration
Flight settings
Input devices
Creating new mappings
The software comes bundled with mappings for Xbox and PS3/4 controllers, but if you have another input-device then it's quick to create your own configuration. Go to the menu Input device -> Configure device mapping.
cfclient configure device
cfclient configure device axis
cfclient configure device detect
Follow the instructions to detect the axis or button that you would like to map to the functionality. If you would like to map the functionality to two axis (like right/left sholder-button) then select Combined axis detection and follow the instructions.
cfclient configure device feedback
Selecting device
The Input device menu contains a number of different "modes" that can be used for controlling a Crazyflie. Currently there's thee to choose from. The alternatives will only be enabled if there's enough input devices connected to use them.
cfclient devices normal
cfclient devices mux select
cfclient input teacher
cfclient input student
cfclient input mux configured
Tabs
The main interface is built up of different tabs that can be shown/hidden from the View->Tabs menu.
Flightcontrol
The normal view used when flying is the one seen below. cfclient flighttab
    • Assisted mode selection. The assisted mode is enabled when the assisted mode button is pressed on the Gamepad.
    • Roll/pitch trim can be set either in the UI or using the controller (if the correct buttons are mapped). This will offset the input to the Crazyflie for correcting imbalance and reducing drift.
    • Advanced flight control settings are available if Advanced mode has been selected (settings are in %):
      • Max yaw rate:Set the max yaw rate allowed
    • Settings for flight decks, currently the LED-ring effect and headlights can be set (if the ring is attached)
    • Target values sent from the client for controlling the Crazyflie
    • Actual values logged from the Crazyflie
    • Motor output on the Crazyflie
    • Horizon indicator
Plotter
The plotter tab can be used to visualize data logged from the Crazyflie cfclient plotter
Parameters
The Crazyflie supports parameters, variables stored in the Crazyflie that can be changed in real-time. The parameter tab can be used to view and update parameters. For more information about parameters see logging and parameter frameworks LINK TO CF-FIRMWARE!
cfclient parameter list
    • Group: To make things easier each group has it’s members organized as sub-nodes to the group
    • Parameters: The full name of each parameter is the group combined with the name (group.name)
Log blocks
cfclient log blocks
  1. Fields
    • ID: Block id in Crazyflie
    • Name: Block name in client
    • Write to <file:> Marked if writing to file, clock to start/stop writing. The data will be written in the configuration folder for the client (see <here> how to find it).
Timestamp,pm.vbat
9103,3.74252200127
10103,3.74252200127
11103,3.74252200127
12103,3.74252200127
13103,3.74252200127
Console
The console tab will show printouts from the Crazyflie firmware as it's running. cfclient console
Loco Positioning
To setup the LPS anchor system mode (TWR or TDoA), see the Configure LPS positioning mode wirelessly documentation.
Position estimate mode
Displays the configured anchor positions and the estimated position of the Crazyflie. Can be used to make sure the system is set up correctly and that the estimated position is reasonable.
cfclient positioning
  1. Plot for X/Y (top view) showing anchors and Crazyflie
  2. Plot for X/Z showing anchors and Crazyflie
  3. Plot for Y/Z showing anchors and Crazyflie
  4. Sets the graph mode
    • Position estimate - Normal viewing mode
    • Anchor identification - Enhanced mode where anchor id and marker becomes larger when Crazyflie is closer
  5. Indicates if anchors are communicating with Crazyflie (i.e anchors are up and running)
  6. Fit and center all data in graphs
  7. Used to set anchor positions (see below)
When setting the anchor position there's three colors to indicate the status:
  • White - No position exists for this anchor (i.e the position has not been read yet)
  • Red - Position has been read from the anchor and it differs from the currently shown value in the input box
  • Green - Position has been read from the anchor and it is the same as the currently shown value in the input box
The positions of the anchors is continuously read in the background and as positions comes in or input box values changes the colors will be set accordingly. There's also two buttons used for the settings:
  • Get from anchors - Fills the input boxes with the positions read from the anchors
  • Write to anchors - Writes the currently shown values in the input boxes to the anchors. In order to check that the write has been successful wait about 10s and all the fields should turn green as the positions are read back. If some of the fields are still red, try pressing the button again.
Anchor identification mode
displays the configured anchor positions. When the crazyflie is close to an anchor this is indicated in the graphs by highlighting it. This mode is useful to identify anchors and verify that the system is correctly configured. cfclient anchors
  5. Current system mode indication. The system must be in TWR mode for the anchor identification mode to be available.
ZMQ backends
