Dependencies
You’ll need to use either the Crazyflie VM, the toolbelt or install some ARM toolchain.
Install a toolchain
OS X
brew tap PX4/homebrew-px4
brew install gcc-arm-none-eabi
Debian/Ubuntu
Tested on Ubuntu 14.04 64b, Ubuntu 16.04 64b, and Ubuntu 18.04 64b:
For Ubuntu 14.04 :
sudo add-apt-repository ppa:terry.guo/gcc-arm-embedded
sudo apt-get update
sudo apt-get install libnewlib-arm-none-eabi
For Ubuntu 16.04 and Ubuntu 18.04:
sudo add-apt-repository ppa:team-gcc-arm-embedded/ppa
sudo apt-get update
sudo apt install gcc-arm-embedded
Note: Do not use the gcc-arm-none-eabi
package that is part of the Ubuntu repository as this is outdated.
Arch Linux
sudo pacman -S community/arm-none-eabi-gcc community/arm-none-eabi-gdb community/arm-none-eabi-newlib
Windows
The GCC ARM Embedded toolchain for Windows is available at launchpad.net. Download the zip archive rather than the executable installer. There are a few different systems for running UNIX-style shells and build systems on Windows; the instructions below are for Cygwin.
Install Cygwin with setup-x86_64.exe. Use the standard C:\cygwin64
installation directory and install at least the make
and git
packages.
Download the latest gcc-arm-none-eabi-*-win32.zip
archive from launchpad.net. Create the directory C:\cygwin64\opt\gcc-arm-none-eabi
and extract the contents of the zip file to it.
Launch a Cygwin terminal and run the following to append to your ~/.bashrc
file:
echo '[[ $PATH == */opt/gcc-arm-none-eabi/bin* ]] || export PATH=/opt/gcc-arm-none-eabi/bin:$PATH' >>~/.bashrc
source ~/.bashrc
Verify the toolchain installation with arm-none-eabi-gcc --version
Cloning
This repository uses git submodules. Clone with the --recursive
flag
git clone --recursive https://github.com/bitcraze/crazyflie-firmware.git
If you already have cloned the repo without the --recursive
option, you need to
get the submodules manually
cd crazyflie-firmware
git submodule init
git submodule update
Compiling
Crazyflie 2.X
This is the default build so just running make
is enough or:
make PLATFORM=cf2
or with the toolbelt
tb make PLATFORM=cf2
Roadrunner
Use the tag
platform
make PLATFORM=tag
tb make PLATFORM=tag
config.mk
To create custom build options create a file called config.mk
in the tools/make/
folder and fill it with options. E.g.
PLATFORM=CF2
DEBUG=1
CLOAD=0
Make targets:
all : Shortcut for build
compile : Compile cflie.hex. WARNING: Do NOT update version.c
build : Update version.c and compile cflie.elf/hex
clean_o : Clean only the Objects files, keep the executables (ie .elf, .hex)
clean : Clean every compiled files
mrproper : Clean every compiled files and the classical editors backup files
cload : If the crazyflie-clients-python is placed on the same directory level and
the Crazyradio/Crazyradio PA is inserted it will try to flash the firmware
using the wireless bootloader.
flash : Flash .elf using OpenOCD
halt : Halt the target using OpenOCD
reset : Reset the target using OpenOCD
openocd : Launch OpenOCD
