For communicating with the Crazyflie we have implemented our own high-level protocol named CRTP (Crazy RealTime Protocol). It's a fairly simple protocol using a number of target ports where data can be sent and received in either direction, but in most cases the communication is driven from the host. The protocol can be implemented on a number of mediums, currently we have USB and Crazyradio support.
CRTP
Physical carriers
Currently CRTP is supported over Crazyradio and USB (currently only for Crazyflie 2.0).
Carrier | Supports |
Crazyradio (PA) | Crazyflie 1.0/2.0 |
USB | Crazyflie 2.0 |
Header
Each packet has a 1 byte header and can carry up to 29 bytes data payload. The header field has the following layout:
7 6 5 4 3 2 1 0
| Port | Link | Chan. |
Where:
- Port: Used to identify the functionality or task that is associated with this message
- Link: Reserved for future use
- Channel: Used to identify the sub-task/functionality
Port allocation
Current port allocation:
Port | Target | Used for |
0 | Console | Read console text that is printed to the console on the Crazyflie using consoleprintf |
2 | Parameters | Get/set parameters from the Crazyflie. Parameters are defined using a macro in the Crazyflie source-code |
3 | Commander | Sending control set-points for the roll/pitch/yaw/thrust regulators |
4 | Memory access | Accessing non-volatile memories like 1-wire and I2C (only supported for Crazyflie 2.0) |
5 | Data logging | Set up log blocks with variables that will be sent back to the Crazyflie at a specified period. Log variables are defined using a macro in the Crazyflie source-code |
6 | Localization | Packets related to localization |
7 | Generic Setpoint | Allows to send setpoint and control modes |
13 | Platform | Used for misc platform control, like debugging and power off |
14 | Client-side debugging | Debugging the UI and exists only in the Crazyflie Python API and not in the Crazyflie itself. |
15 | Link layer | Used to control and query the communication link |
Connection procedure
CRTP is designed to be state-less, so there's no handshaking procedure that is needed. Any command can be sent at any time, but for some logging/param/mem commands the TOC (table of contents) needs to be downloaded in order for the host to be able to send the correct information. The implementation of the Pyton API will download the param/log/mem TOC at connect in order to be able to use all the functionality.
