On-chip debugging
One of the key components of getting really serious about developing on the crazyflie, is to dive into the C-based firmware. If you really want to do some major changes to the intrinsic of the code, it is essential to have proper tools to be able to debug the code (place breakpoints, read real-time values ect...). On this page, we will put a few examples how to do this with IDE's and different environments.
NOTE: This page requires our debug adapter and ST Link V2 Debugger! See this page: Debug adapter
Debugging using eclipse
Ubuntu
Versions:
  • Ubuntu 18.04.2 LTS (64 bit)
  • Eclipse 2019-03 (Eclipse IDE for C/C++ Developers)
Installing prerequisites
sudo apt-get update
sudo apt-get install gdb
sudo apt-get install openocd
Then install java:
sudo apt install default-jre
Then install eclipse itself: Go to their download page: eclipse 20 and then go into you download folder and unzip the file.
and start up eclipse:
  • C++ Development - Follow the instructions under the header 'CDT'.
  • GNU MCU plugin - Follow the instructions under the header 'Plug-ins install/update -> The Eclipse Marketplace way'
Import Crazyflie Firmware
  • File > import…
  • C/C++ > Existing Code as Makefile Project -> Next
  • Give it a name
  • Existing Code Location > Browse… > //Look for the firmware folder//
  • //Toolchain for Indexer Settings// can be ignored.
  • Finish
  • Go to: Run > Debug Configurations...
  • Double click 'GDB OpenOCD Debugging'
Main
stm openocd main
Debugger
stm openocd debug
  • Executable name: Filepath to gdb toolchain
  • Commands: <code> set mem inaccessible-by-default off </code>
Startup
stm openocd startup
Hit Debug!
Make sure that your cf2.elf is the same as the one you uploaded to the crazyflie!
Mac OS
Install gdb and openocd
brew install gdb
brew install open-ocd
Install java JDK java download
Download eclipse eclipse download
Run eclipse and choose work folder
Installing required eclipse Plugins
