This page aims at documenting how to start developing with Crazyflie. This document should work for the Crazyflie 2.X.
STM32
Clone the crazyflie-firmware project, or update it using the virtual machine "Update all projects" script. For Crazyflie 2.X make sure the current branch is "master."
~$ cd projects/crazyflie-firmware/
crazyflie-firmware$ git checkout master
Then make the firmware.
For Crazyflie 2.X:
crazyflie-firmware$ make PLATFORM=cf2
DFUse cf2.dfu
Crazyflie 2.0 build!
Build 00:00000000 (20XX.XX.X-XX) CLEAN
Version extracted from git
Crazyloader build!
text data bss dec hex filename
XXXXX XXXX XXXXX XXXXXX XXXXX cf2.elf
rm version.c
To program using the radio bootloader, first install the cflib and cfclient, and put the CF2.X in bootloader mode:
For Crazyflie 2.X:
From command line the flash make target flashed the firmware using programming cable
crazyflie-firmware$ make flash
Command line
make flash
