Dependencies
You’ll need to use either the Crazyflie VM, the toolbelt or install some ARM toolchain.
Install a toolchain
OS X
brew tap PX4/homebrew-px4
brew install gcc-arm-none-eabi
Debian/Ubuntu
Tested on Ubuntu 14.04 64b, Ubuntu 16.04 64b, and Ubuntu 18.04 64b:
For Ubuntu 14.04 :
sudo add-apt-repository ppa:terry.guo/gcc-arm-embedded
sudo apt-get update
sudo apt-get install libnewlib-arm-none-eabi
For Ubuntu 16.04 and Ubuntu 18.04:
sudo add-apt-repository ppa:team-gcc-arm-embedded/ppa
sudo apt-get update
sudo apt install gcc-arm-embedded
Note: Do not use the gcc-arm-none-eabi
package that is part of the Ubuntu repository as this is outdated.
Arch Linux
sudo pacman -S community/arm-none-eabi-gcc community/arm-none-eabi-gdb community/arm-none-eabi-newlib
Windows
The GCC ARM Embedded toolchain for Windows is available at launchpad.net. Download the zip archive rather than the executable installer. There are a few different systems for running UNIX-style shells and build systems on Windows; the instructions below are for Cygwin.
Install Cygwin with setup-x86_64.exe. Use the standard C:\cygwin64
installation directory and install at least the make
and git
packages.
Download the latest gcc-arm-none-eabi-*-win32.zip
archive from launchpad.net. Create the directory C:\cygwin64\opt\gcc-arm-none-eabi
and extract the contents of the zip file to it.
Launch a Cygwin terminal and run the following to append to your ~/.bashrc
file:
echo '[[ $PATH == */opt/gcc-arm-none-eabi/bin* ]] || export PATH=/opt/gcc-arm-none-eabi/bin:$PATH' >>~/.bashrc
source ~/.bashrc
Verify the toolchain installation with arm-none-eabi-gcc --version
Cloning
This repository uses git submodules. Clone with the --recursive
flag
git clone --recursive https://github.com/bitcraze/crazyflie-firmware.git
If you already have cloned the repo without the --recursive
option, you need to
get the submodules manually
cd crazyflie-firmware
git submodule init
git submodule update
Compiling
Crazyflie 2.X
This is the default build so just running make
is enough or:
make PLATFORM=cf2
or with the toolbelt
tb make PLATFORM=cf2
Roadrunner
Use the tag
platform
make PLATFORM=tag
tb make PLATFORM=tag
config.mk
To create custom build options create a file called config.mk
in the tools/make/
folder and fill it with options. E.g.
PLATFORM=CF2
DEBUG=1
CLOAD=0
Out of tree build
By setting the Makefile variable CRAZYFLIE_BASE
, it is possible to build the Crazyflie
from outside the project folder. This can be used to implement autonomous behaviour on
top of the Crazyflie firmware by compiling external code in the firmware from an external
repos.
For example, if you have a deck driver file called push.c
that creates a deck driver for
the deck bcPush
. You can create a new git repos with crazyflie-firmware
clonned as
submodule and put push.c
in a folder src
. The makefile to build a firmware starting
your deck driver automatically will be:
CRAZYFLIE_BASE=crazyflie-firmware
CFLAGS += -DDECK_FORCE=bcPush
VPATH += src/
PROJ_OBJ += push.o
include $(CRAZYFLIE_BASE)/Makefile
Note that CFLAGS += -DDECK_FORCE=bcPush
is what would normally be added to config.mk
Hence, this method also allow to create build configurations folder by building the firmware is a
separate folder with separate configurations.
Both tools/make/config.mk
and current_platform.mk
are sourced from the current folder
and not from the Crazyflie firmware folder.
Make targets:
all : Shortcut for build
compile : Compile cflie.hex. WARNING: Do NOT update version.c
build : Update version.c and compile cflie.elf/hex
clean_o : Clean only the Objects files, keep the executables (ie .elf, .hex)
clean : Clean every compiled files
mrproper : Clean every compiled files and the classical editors backup files
cload : If the crazyflie-clients-python is placed on the same directory level and
the Crazyradio/Crazyradio PA is inserted it will try to flash the firmware
using the wireless bootloader.
flash : Flash .elf using OpenOCD
halt : Halt the target using OpenOCD
reset : Reset the target using OpenOCD
openocd : Launch OpenOCD
