Making your first Deck driver
This howto is going to describe step-by-step how to make and flash your first Crazyflie 2.X deck driver. See the deck api documentation page for more information about the code.
Development environment
Writing the driver
#include "debug.h"
#include "deck.h"
static void helloInit()
  DEBUG_PRINT("Hello Crazyflie 2.0 deck world!\n");
static bool helloTest()
  DEBUG_PRINT("Hello test passed!\n");
  return true;
  .name = "myHello",
  .init = helloInit,
  .test = helloTest,
DECK_DRIVER(helloDriver);
Adding the driver to the build
PROJ_OBJ += hello.o
Enabling the driver
Decks can have a memory that contains its name. In our case the hello driver would be initialised only when a deck identified as "myHello" is installed on the Crazyflie. For development purpose it is possible to force enabling a deck driver with a compile flag. To do so create the file tools/make/config.mk with the content:
CFLAGS += -DDECK_FORCE=myHello
DEBUG=1
Note Each time you modify config.mk you should recompile the full firmware by cleaning up the build folder with 'make clean'
Compile, flash and run!
crazyflie-firmware$ make
  CC    hello.o
Crazyflie 2.0 build!
Build 44:61f3d878233d (2015.08.1-44) MODIFIED
Version extracted from git
Crazyloader build!
   text    data     bss     dec     hex filename
 130660    1636   29828  162124   2794c cf2.elf
rm version.c
../crazyflie-clients-python/bin/cfloader flash cf2.bin stm32-fw
 10 seconds ...
 done!
Connected to bootloader on Crazyflie 2.0 (version=0x10)
Target info: nrf51 (0xFE)
Target info: stm32 (0xFF)
Flashing 1 of 1 to stm32 (fw): 161867 bytes (159 pages) ..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10..........10.........9
Reset in firmware mode ...
deck hello console
