Introduction
App entry-point
When compiling the Crazyflie with APP=1
writen either in the Makefile or in tools/make/config.mk
the firmware will call a function void appMain()
from a task after the startup sequence has completed.
This function should not return.
If you want more control, you can define a function void appInit()
. appInit()
will be called by the firmware during initialisation, no task will be created and so appMain()
will not be automaticall called.
This function must return to allow the Crazyflie initialization sequence to continue.
The folowing Makefile variables can be used for configuration:
- APP: Set to ‘1’ to enable the app entry-point
- APP_STACKSIZE: Set the task stack size in 32bit word (4 Bytes). The default is 300 (1.2KBytes)
- APP_PRIORITY: Set the task priority between 0 and 5. Default is 0 (same as IDLE).
