One of the key components of getting really serious about developing on the crazyflie, is to dive into the C-based firmware. If you really want to do some major changes to the intrinsic of the code, it is essential to have proper tools to be able to debug the code (place breakpoints, read real-time values ect...). On this page, we will put a few examples how to do this with IDE's and different environments.
NOTE: This page requires our debug adapter and ST Link V2 Debugger! See this page: Debug adapter
Debugging using eclipse
Ubuntu
Versions:
- Ubuntu 18.04.2 LTS (64 bit)
- Eclipse 2019-03 (Eclipse IDE for C/C++ Developers)
Installing prerequisites
sudo apt-get update
sudo apt-get install gdb
sudo apt-get install openocd
Then install java:
sudo apt install default-jre
Then install eclipse itself: Go to their download page: eclipse 20 and then go into you download folder and unzip the file.
and start up eclipse:
- C++ Development - Follow the instructions under the header 'CDT'.
- GNU MCU plugin - Follow the instructions under the header 'Plug-ins install/update -> The Eclipse Marketplace way'
Import Crazyflie Firmware
- File > import…
- C/C++ > Existing Code as Makefile Project -> Next
- Give it a name
- Existing Code Location > Browse… > //Look for the firmware folder//
- //Toolchain for Indexer Settings// can be ignored.
- Finish
- Go to: Run > Debug Configurations...
- Double click 'GDB OpenOCD Debugging'
Main
Debugger
- Executable name: Filepath to gdb toolchain
- Commands: <code> set mem inaccessible-by-default off </code>
Startup
Hit Debug!
Make sure that your cf2.elf is the same as the one you uploaded to the crazyflie!
Mac OS
Install gdb and openocd
brew install gdb
brew install open-ocd
Install java JDK java download
Download eclipse eclipse download
Run eclipse and choose work folder
Installing required eclipse Plugins
Debugging using VS Code
For those of you who prefer using VS Code for everything, thanks to the Cortex-Debug extension, it is now possible to debug ARM executables straight inside of VS Code!
Mac OS and Ubuntu
Prerequisites
First ensure that you have the ARM GCC toolchain and OpenOCD installed and in your path. To check, run:
which openocd
which arm-none-eabi-gcc
The path to your OpenOCD binary and ARM GCC binary should output. If not, try installing them again.
For the ARM GCC toolchain:
Ubuntu
sudo apt-get install arm-none-eabi-gcc
Mac OS
brew tap PX4/homebrew-px
brew install arm-none-eabi-gcc
The Cortex Debug Extension
Install the extension either by clicking “Install” on the web page, or by searching “Cortex Debug” in the Extensions tab of VS Code.
Click on “Run”, then “Add Configuration”, then “Cortex Debug”.
This should automatically create the needed “launch.json” file.
Configuring Cortex Debug
Inside of the file, replace everything with the following:
"version": "0.2.0",
"configurations": [
"name": "Cortex Debug",
"cwd": "${workspaceRoot}",
"executable": "./cf2.elf",
"request": "launch",
"type": "cortex-debug",
"device": "STM32F405",
"svdFile": "STM32F405.svd",
"servertype": "openocd",
"configFiles": ["interface/stlink-v2.cfg", "target/stm32f4x.cfg"],
"runToMain": true,
"preLaunchCommands": [
"enable breakpoint",
"monitor reset"
Explaining the Cortex Debug configuration
- “svdFile” refers to the necessary file for peripheral registers to show up nicely in the debug pane, all named and structured; we’ll add it in the next step
- “configFiles” refers to the files you need so that OpenOCD knows what device and interface you’re using; it should already come with them
- “runToMain” tells the GDB debug server to jump to main by default
- “preLaunchCommands” specifies the commands for the GDB server to send before giving away control to you; the commands here mimic the options that the above tutorial for Eclipse specifies
Installing the SVD file
Now for the SVD file: just download it from here and into your root directory. Make sure it has the exact name of “STM32F405.svd”!
Debugging!
After all this, go to the Debug tab of VS Code (on the left sidebar, the icon with the little bug next to the play button), and hit that play button next to “Run”!
If you followed everything, it should start running nicely and look a little something like this:
Notice the nice peripherals pane at the bottom, along with the variables pane at the top. Awesome, now you can code and debug all within VS Code!
