Introduction
App entry-point
When compiling the Crazyflie with APP=1
writen either in the Makefile or in tools/make/config.mk
the firmware will call a function void appMain()
from a task after the startup sequence has completed.
This function should not return.
If you want more control, you can define a function void appInit()
. appInit()
will be called by the firmware during initialisation, no task will be created and so appMain()
will not be automaticall called.
This function must return to allow the Crazyflie initialization sequence to continue.
The folowing Makefile variables can be used for configuration:
- APP: Set to ‘1’ to enable the app entry-point
- APP_STACKSIZE: Set the task stack size in 32bit word (4 Bytes). The default is 300 (1.2KBytes)
- APP_PRIORITY: Set the task priority between 0 and 5. Default is 0 (same as IDLE).
Internal log and param system
For the app-layer, it would be good to have access to log and/or parameter values and to set parameter values. This way, your app will be able to read out sensor data or to switch controller/estimator on air. To check out these functions, look at src/modules/interface/log.h or …/param.h for the internal access functions.
Examples
In the example folder of the crazyflie-firmware repository, there are several examples shown tha tuse the app layer, including a simple hello world example.
