Sensor to control
This page is meant as an introduction and overview of the path from sensor acquisition to motor control. It will not go into detail but it mostly give a general outline of how the sensor measurements go to the state estimators to the controllers and finally distributed to the motors by power distribution. Ofcourse, the motors have an affect on how the crazyflie flies and that inderectly has an effect on what the sensors detect in the next time step.
sensor
Modules
Sensors
================== Sensors are essential for the flight of a crazyflie. Here is a table with the sensors listed that the crazyflie eventually uses for state estimation:
Location Type Measurement Unit Sensor driver
On-board Sensors Accelerometer acceleration in body fixed coordinates m/s2 BMI088 sensors_bmi088_bmp388.c
” “ Gyroscope angle rate in roll pitch and yaw rad/s ” “ ” “
” “ Pressure Sensor Airpressure mBar BMP388 ” “
Z-ranger v2 ToF sensor* Distance to a surface milimeters VL53L1x vl53l1x.c
Flowdeck v2** Optical flow sensor The detection movement of pixels px per timesample PMW3901 pmw3901.c
LPS deck Ultra Wide band The Distance between two UWB modules or TDOA*** meters DWM1000 locodeck.c
Lighthouse deck IR receivers Sweep angle of htc vive basestations rad TS4231 lighthouse.c
*Time-of-Flight
**Also contains a laser-ranger
***Time-difference of Arrival
State Estimation
There are 2 state estimators in the crazyflie:
  • Complementary Filter
  • Extended Kalman Filter
For more indepth information about how the state estimation is implemented in the crazyflie firmware, please go to the state estimation page
State Controller
There are 3 controllers in the crazyflie
  • PID controller
  • INDI controller
  • Mellinger controller
For more indepth information about how the controllers are implemented in the crazyflie firmware, please go to the controllers page
Commander Framework
An desired state can be handled by the setpoint structure in position or atitude, which can be set by the cflib or the highlevel commander
For more indepth information about how the commander framework are implemented in the crazyflie firmware, please go to the commander page
Power Distribution
After the state controller has send out its commands, this is not the end of the line yet. The controllers send out their commands relating to their yaw, roll and pitch angles. How the motors should respond in order to adhere these attitude based commands depends on a few factors:
  • Quadrotor configuration (found in: power_distribution_stock.c):
    • x-configuration: The body fixed coordinate system’s x-axis is pointed in between two propellors (Default)
    • +-configuration: The body fixed coordinate system’s x-axis is pointed in one propellor
  • Motors:
    • Explaination about this will come soon
