Development for NRF51
This page aims at documenting how to start developing with the Crazyflie 2.X NRF51 chip. Make sure that you have soldered the nrf debug connector first, which is provided with debug adapter kit (see the ‘usage’ tab)
nRF51
Clone the crazyflie2-nrf-firmware project.
Then make the firmware:
make clean
make
To flash, first install the cflib and cfclient, and put the CF2.X in bootloader mode.
To flash using the radio bootloader:
make cload
To flash using a programming cable:
make flash
Debugging
Debugging the nRF51 chip requires a different configuration, but is otherwise identical to debugging the STM32. The alternative configuration can be found below.
NOTE: Make sure your executable (cf2_nrf.elf) is identical to the one running on your Crazyflie.
Debugging in VS Code
The Cortex Debug Configuration for nRF51 debugging is replaced with:
    "version": "0.2.0",
    "configurations": [
            "name": "nRF51 Debug",
            "cwd": "${workspaceRoot}",
            "executable": "./cf2_nrf.elf",
            "request": "launch",
            "type": "cortex-debug",
            "device": "nrf51822",
            "servertype": "openocd",
            "interface": "swd",
            "configFiles": [
                "interface/stlink-v2.cfg",
                "target/nrf51.cfg"
            "runToMain": true,
            "preLaunchCommands": [
                "enable breakpoint",
                "monitor reset"
Debugging in Eclipse
Replace cf2.elf with cf2_rbf.elf Replace target/stm32f4x.cfg with target/nrf51.cfg
Note on programming cables
For debugging and flashing without a radio an SWD cable is required. By default any cable supported by OpenODC can be used. The STLink-V2 is used by the Bitcraze team. Other cables like JLink can also be used but will require to manually enter the flashing command line and to modify your (VS Code/Eclipse) debugging configuration accordingly.
The SEGGER J-LINK can be used for debugging and flashing.
  • Download and install a recent version of OpenOCD, you will need at least version 0.9.
  • (Optional) Download and install (or extract) the J-Link Software. The following was tested with version 5.10u.W
    • If there is an error, you can execute the following once and type connect in the command prompt. This fixes issues in case openOCD left the J-Link in an invalid state.
    ./JLinkExe -device STM32F405RG -if swd -speed 4000
