Testing the Himax camera on the AIdeck
This concerns the example in folder examples/other/test_functionalities/test_camera/.
In the makefile enable APP_CFLAGS += -DASYNC_CAPTURE if you want to test the asynchronous camera capture and remove it if you want to test the normal one. To save a color image enable APP_CFLAGS += -DCOLOR_IMAGE. And, to capture a 324x244 (QVGA) image instead of a 324x324 image, enable APP_CFLAGS += -DQVGA_MODE. Please note though that capturing an image in non-QVGA mode might not always work correctly.
To test out the code, first, source the AIdeck config (configs/ai_deck.sh) in your terminal and write
make clean all run io=host
for directly running the code from L2 (second level internal memory) with your programmer.
Run in Docker
To build and execute in the docker we need to place the demosaicking-files in the common-folder inside the docker.
docker run --rm -it -v $PWD:/module/data/ --device /dev/ttyUSB0 --privileged -P bitcraze/aideck /bin/bash -c 'export GAPY_OPENOCD_CABLE=interface/ftdi/olimex-arm-usb-tiny-h.cfg; source /gap_sdk/configs/ai_deck.sh; cd /module/data/; make clean all run'
