Flightcontrol Tab
cfclient flighttab
    • Hover: When activated, keeps the Crazyflie at 40cm above the ground and tries to keep the position in X and Y as well. Thrust control becomes height velocity control. Requires a flow deck. Uses body-fixed coordinates.
    • Max yaw rate:Set the max yaw rate allowed
  9. Horizon indicator
  10. Command based flight control, allow controlled flight if, and only if, a positioning deck such as the Flow deck, the Loco deck or the Lighthouse deck is present.
