| OK, got it! |
Unit testing
Dependencies
Frameworks for unit testing and mocking are pulled in as git submodules.
The testing framework uses ruby and rake as well as libasan (AddressSanitizer) to generate and run code. If you run the tests on your own machine you will have to install them.
To minimize the need for installations and configuration, use the docker builder image (bitcraze/builder) that contains all tools needed. All scripts in the tools/build directory are intended to be run in the image. The toolbelt makes it easy to run the tool scripts.
Running all unit tests
With the environment set up locally
    make unit
with the docker builder image and the toolbelt
    tb make unit
Running one unit test
When working with one specific file it is often convenient to run only one unit test
   make unit FILES=test/utils/src/test_num.c
or with the toolbelt
   tb make unit FILES=test/utils/src/test_num.c
Running unit tests with specific build settings
The unit tests are affected by the settings in kbuild and the defines that are set in the configuration will be used in the unit tests as well. In some cases unit tests must be disabled based on the configuration, for instance if a particular file is not included in the build. A unit test file can be disabled based on configuration by using an annotation like this:
// @IGNORE_IF_NOT CONFIG_DECK_LIGHTHOUSE
