DeckCtrl protocol specification
The DeckCtrl backend implements an I2C-based deck and control discovery mechanism that uses microcontrollers on deck boards (deck controllers) to enable dynamic enumeration of multiple decks. The microcontroller implementing the DeckCtrl protocol is exclusively used for that purpose, deck functionalities are implemented on another chip/microcontroller.
Discovery Sequence
The DeckCtrl backend performs the following sequence during initialization:
1. Reset Phase (Address 0x41)
All deck controllers on the bus listen to the reset address. A read operation to this address causes all controllers to reset their I2C configuration and return to default state.
i2cdevReadReg16(I2C1_DEV, 0x41, 0x0000, 2, dummy_buffer);
vTaskDelay(10); // Wait for controllers to restart
2. Listening Mode (Address 0x42)
After reset, the unconfigured deck controllers must be told to enter listening mode. In this state, they monitor the bus for address assignment.
i2cdevReadReg16(I2C1_DEV, 0x42, 0x0000, 2, dummy_buffer);
3. Enumeration
For each deck to be discovered:
3a. Read CPU ID (Address 0x43, Register 0x1900)
We read the next unconfigured deck with the lowest ID. The other decks will observe a bus collision and back-off, they will then be ready to be put back in listening mode in step 2.
uint8_t cpu_id[12];
i2cdevReadReg16(I2C1_DEV, 0x43, 0x1900, 12, cpu_id);
Note: This is the core of the discovery protocol, it uses the native anticollision behavior of I2C to be able to detect decks one by one. I2C detects a collision if it tries to let the open-collector data line high while another deck is pulling it low. The deck that wanted it high will detect the line low, assume a collision, and back-off
3b. Assign Address (Address 0x43, Register 0x1800)
Write a unique I2C address to the deck controller. The address range starts at 0x44:
uint8_t deck_address = 0x44 + deck_count;
i2cdevWriteReg16(I2C1_DEV, 0x43, 0x1800, 1, &deck_address);
After receiving its address, the deck removes itself from the default addresses and begins responding only to its assigned address.
3c. Read Deck Information (Assigned Address, Register 0x0000)
Read the deck’s identification and capability information from its newly assigned address:
uint8_t deck_info[21];
i2cdevReadReg16(I2C1_DEV, deck_address, 0x0000, 21, deck_info);
4. Repeat
Return to step 2 (listening mode) to discover the next deck. Continue until no more decks respond.
I2C Address Map
| Address | Purpose | Description |
| 0x41 | Reset | Broadcast reset to all deck controllers |
| 0x42 | Listen | Put unconfigured controllers in listening mode |
| 0x43 | Default | Read CPU ID and assign unique address |
| 0x44-0x4F | Assigned | Individual deck addresses (up to 12 decks) |
The maximum number of decks is configured via CONFIG_DECK_BACKEND_DECKCTRL_MAX_DECKS.
Memory Layout
Register Map
Once configured, the deck-control behaves like an I2C memory with the following memory map:
| Register | Size | Description |
| 0x0000 | 32 | Deck identification information (Read-only) |
| 0x0020 | 2016 | ROM partitions |
| 0x1000 | 4 | GPIO |
| 0x1800 | 1 | Address assignment (write-only) |
| 0x1900 | 12 | CPU unique ID (read-only) |
Deck Information Format (Register 0x0000)
The 32-byte deck information block contains:
| Offset | Size | Field | Description |
| 0x00 | 2 | Magic | Magic number 0xBCDC (big-endian) |
| 0x02 | 1 | Major Version | Firmware major version |
| 0x03 | 1 | Minor Version | Firmware minor version |
| 0x04 | 1 | Vendor ID | Deck vendor ID |
| 0x05 | 1 | Product ID | Deck product ID |
| 0x06 | 1 | Board Revision | Board revision character |
| 0x07 | 15 | Product Name | Null-terminated product name string |
| 0x16 | 1 | Manufacturing year | Year of manufacture (from 2000) |
| 0x17 | 1 | Manufacturing month | Month of manufacture (1-12) |
| 0x18 | 1 | Manufacturing day | Day of manufacture (1-31) |
| 0x19 | 6 | Reserved | Reserved for future use |
| 0x1F | 1 | Checksum | Value to make the checksum (modulo 256) of bytes 0-31 equal to zero |
Magic Number
All valid DeckCtrl decks must return the magic number 0xBCDC in the first two bytes. This validates that the device is a proper DeckCtrl deck.
Format: Big-endian (0xBC at offset 0, 0xDC at offset 1)
Vendor ID and Product ID
The VID/PID pair uniquely identifies the deck type and is used to match with the appropriate deck driver in firmware. These should match the vid and pid fields in the DeckDriver structure.
Product Name
A human-readable name for the deck (up to 14 characters plus null terminator). This is used for logging and debugging.
Backend Context
Each discovered DeckCtrl deck receives a DeckCtrlContext structure that contains backend-specific data:
typedef struct deckCtrlContext_s {
uint8_t i2cAddress; // Assigned I2C address (0x44+)
} DeckCtrlContext;
Deck drivers can access this context through the DeckInfo structure passed to their init() function:
void myDeckInit(DeckInfo *info) {
DeckCtrlContext *ctx = (DeckCtrlContext *)info->backendContext;
uint8_t address = ctx->i2cAddress;
// Use address for I2C communication with the deck
ROM Partition formats (address 0x0020)
The space is split in partitions with the following format:
| 0x00 | 2 | Length | Partition full size, 0x0000 if no more partition |
| 0x02 | 4 | Type | Partition type |
| 0x06 | Length - 6 | Data | Partition data |
At offset length the next partition is starting. A length of 0x0000 denote the end of the partition table. A length between 1 and 5 included is invalid.
There are no partition type defined yet. This mechanism is designed to allow for future expansion.
GPIO control
| Offset | Size | Field | Reset value | Description |
| 0x00 | 2 | Direction | 0x00 | GPIO Direction. 0 for input, 1 for output |
| 0x02 | 2 | Value | * | GPIO Value |
