Creating your own platform can be a good way of saving work by …
- Tailoring a config that is specific to your product or project!
- To make sure you have sensible default values for parameters
- Or to make sure that the initialization is done correctly
If you contribute it to the main Bitcraze repository it is also a way to distribute your work! So how do you do it? Follow these steps!
Add your platform to Kconfig
To make it possible to select your platform for the build you need to add it to
a Kconfig
file. You can find the platform selection in the root Kconfig
file.
Right now the selction looks like:
menu "Platform configuration"
choice
prompt "Platform to build"
default CONFIG_PLATFORM_CF2
config PLATFORM_CF2
bool "Build for CF2"
select SENSORS_BMI088_BMP388
select SENSORS_MPU9250_LPS25H
config PLATFORM_BOLT
bool "Build for Bolt"
select SENSORS_BMI088_SPI
config PLATFORM_TAG
bool "Build for the roadrunner"
endchoice
Let’s add our own platform, RINCEWIND
, which has the same sensors as the Bolt.
choice
config PLATFORM_CF2
config PLATFORM_TAG
config PLATFORM_RINCEWIND
bool "Build for the Rincewind platform"
endchoice
This creates the CONFIG_PLATFORM_RINCEWIND
variable, usable both from C code as a define (when you include autoconf.h
) as well as an environment variable usable from the Makefiles and the Kbuild files.
Add a init source file to Kbuild
We need to add a entry point for your platform. The way the build system determines which platform init file to include is found in the src/platform/src/Kbuild
file:
obj-$(CONFIG_PLATFORM_BOLT) += platform_bolt.o
obj-$(CONFIG_PLATFORM_CF2) += platform_cf2.o
obj-$(CONFIG_PLATFORM_TAG) += platform_tag.o
obj-y += platform.o
obj-y += platform_stm32f4.o
obj-y += platform_utils.o
Let’s add RINCEWIND
obj-$(CONFIG_PLATFORM_RINCEWIND) += platform_rincewind.o
obj-y += platform.o
We will base the src/platform/src/platform_rincewind.c
file on the bolt:
#define DEBUG_MODULE "PLATFORM"
#include <string.h>
#include "platform.h"
#include "exti.h"
#include "nvic.h"
#include "debug.h"
static platformConfig_t configs[] = {
#ifdef CONFIG_SENSORS_BMI088_SPI
.deviceType = "CB10",
.deviceTypeName = "Rincewind",
.sensorImplementation = SensorImplementation_bmi088_spi_bmp388,
.physicalLayoutAntennasAreClose = false,
.motorMap = motorMapBoltBrushless,
#endif
const platformConfig_t* platformGetListOfConfigurations(int* nrOfConfigs) {
*nrOfConfigs = sizeof(configs) / sizeof(platformConfig_t);
return configs;
void platformInitHardware() {
// Low level init: Clock and Interrupt controller
nvicInit();
// EXTI interrupts
extiInit();
const char* platformConfigGetPlatformName() {
return "Rincewind";
The platformInitHardware()
and platformGetListOfConfigurations()
functions is called by platform.c
as part of general init of the device.
Add platform default parameter values
Your platform need to define suitable default values to (persistent) parameters. To do this we will need to create a src/platform/interface/platform_rincewind.h
and make sure that this gets included when we build for the RINCEWIND
platform. This is done by adding to the src/platform/interface/platform_defaults.h
#pragma once
#define __INCLUDED_FROM_PLATFORM_DEFAULTS__
#ifdef CONFIG_PLATFORM_CF2
#include "platform_defaults_cf2.h"
#endif
#ifdef CONFIG_PLATFORM_BOLT
#include "platform_defaults_bolt.h"
#endif
#ifdef CONFIG_PLATFORM_TAG
#include "platform_defaults_tag.h"
#endif
Becomes:
#pragma once
#endif
#endif
#endif
#ifdef CONFIG_RINCEWIND
#include "platform_defaults_rincewind.h"
#endif
We base it on the default parameters for the Bolt. To determine how to add content to platform_defaults_rincewind.h
please check what is added to the existing platforms.
Add a platform default config
To make it easier for people to build for RINCEWIND
we can add a defconfig
for it. This is done by adding a file in the configs/
folder. Let us look at bolt_defconfig
CONFIG_PLATFORM_BOLT=y
CONFIG_ESTIMATOR=any
CONFIG_CONTROLLER=Any
CONFIG_POWER_DISTRIBUTION=stock
Based on this a start of rincewind_defconfig
could be:
CONFIG_PLATFORM_RINCEWIND=y
Then RINCEWIND
platform could be built by:
$ make rincewind_defconfig
make[1]: Entering directory '/home/jonasdn/sandbox/kbuild-firmware/build'
GEN ./Makefile
# configuration written to .config
make[1]: Leaving directory '/home/jonasdn/sandbox/kbuild-firmware/build'
$ make -j 12
And you are done! You have created your own platform, good job!
