The lighthouse memory mapping is used to communicate geometry and
calibration data. The implementation supports both read and write
operations.
Memory layout
Address |
Type |
Description |
0x0000 |
Geometry data |
Geometry data for base station on channel 1 |
0x0100 |
Geometry data |
Geometry data for base station on channel 2 |
Geometry data |
0x0f00 |
Geometry data |
Geometry data for base station on channel 16 |
0x1000 |
Calibration data |
Calibration data for base station on channel 1 |
0x1100 |
Calibration data |
Calibration data for base station on channel 2 |
Calibration data |
0x1f00 |
Calibration data |
Calibration data for base station on channel 16 |
Geometry data memory layout
Address |
Type |
Description |
0x0X00 |
float (4 bytes) x 3 |
Base station position, 3 element vector of floats (4 bytes) |
0x0X0C |
float (4 bytes) x 9 |
Base station attitude, 3 x 3 rotation matrix of floats (4 bytes) |
0x0X18 |
uint8 |
Is valid : 0 = the data is not valid, 1 = data is valid |
Calibration data memory layout
Address |
Type |
Description |
0x0X00 |
Calibration sweep data |
Calibration data for first sweep |
0x0X1C |
Calibration data for second sweep |
0x0X38 |
uint32 |
Base station UID |
0x0X3C |
uint8 |
Calibration sweep data memory layout
Address |
Type |
Description |
0x0X00 |
float (4 bytes) |
phase |
0x0X04 |
float (4 bytes) |
tilt |
0x0X08 |
float (4 bytes) |
curve |
0x0X0C |
float (4 bytes) |
gibmag |
0x0X10 |
float (4 bytes) |
gibphase |
0x0X14 |
float (4 bytes) |
ogeemag (only used in LH2) |
0x0X18 |
float (4 bytes) |
ogeephase (only used in LH2) |
