This page aims at documenting how to start developing with the Crazyflie 2.X NRF51 chip
nRF51
Clone the crazyflie2-nrf-firmware project.
Then make the firmware:
make clean
make
To flash, first install the cflib and cfclient, and put the CF2.X in bootloader mode.
To flash using the radio bootloader:
make cload
To flash using a programming cable:
make flash
Debugging
Debugging the nRF51 chip requires a different configuration, but is otherwise identical to debugging the STM32. The alternative configuration can be found below.
NOTE: Make sure your executable (cf2_nrf.elf) is identical to the one running on your Crazyflie.
Debugging in VS Code
The Cortex Debug Configuration for nRF51 debugging is replaced with:
"version": "0.2.0",
"configurations": [
"name": "nRF51 Debug",
"cwd": "${workspaceRoot}",
"executable": "./cf2_nrf.elf",
"request": "launch",
"type": "cortex-debug",
"device": "nrf51822",
"servertype": "openocd",
"interface": "swd",
"configFiles": [
"interface/stlink-v2.cfg",
"target/nrf51.cfg"
"runToMain": true,
"preLaunchCommands": [
"enable breakpoint",
"monitor reset"
Debugging in Eclipse
Replace cf2.elf with cf2_rbf.elf Replace target/stm32f4x.cfg with target/nrf51.cfg
Note on programming cables
For debugging and flashing without a radio an SWD cable is required. By default any cable supported by OpenODC can be used. The STLink-V2 is used by the Bitcraze team. Other cables like JLink can also be used but will require to manually enter the flashing command line and to modify your (VS Code/Eclipse) debugging configuration accordingly.
J-LINK
The SEGGER J-LINK can be used for debugging and flashing.
- Download and install a recent version of OpenOCD, you will need at least version 0.9.
(Optional) Download and install (or extract) the J-Link Software. The following was tested with version 5.10u.W
- If there is an error, you can execute the following once and type connect in the command prompt. This fixes issues in case openOCD left the J-Link in an invalid state.
./JLinkExe -device STM32F405RG -if swd -speed 4000
