On this step by step guide we will show you how to connect to your Crazyflie through the Crazyflie python library by a python script. This is the starting point for developing for the Crazyflie for off-board enabled flight.
Prerequisites
We will assume that you already know this before you start with the tutorial:
- Some basic experience with python
- Followed the Crazyflie getting started guide.
- Able to connect the crazyflie to the CFClient and look at the log tabs and parameters (here is a userguide).
Install the cflib
Make sure that you have python3, which should contain pip3. In a terminal please write the following:
pip3 install cflib
This should have been installed if you installed the cfclient already (on a linux system), but it is always good to double check this :)
Step 1. Connecting with the Crazyflie
Begin the python script
Open up a python script anywhere that is convenient for you. We use Visual Studio code ourselves but you can use the Python editor IDLE3 if you want.
- For python editor: select file->new
- For VS code: select file-> new file
You can call it connect_log_param.py (that is what we are using in this tutorial).
Then you would need to start with the following standard python libraries.
import logging
import time
then you need to import the libraries for cflib:
import cflib.crtp
from cflib.crazyflie.syncCrazyflie import SyncCrazyflie
from cflib.utils import uri_helper
- The cflib.crtp module is for scanning for Crazyflies instances.
- The Crazyflie class is used to easily connect/send/receive data from a Crazyflie.
- The synCrazyflie class is a wrapper around the “normal” Crazyflie class. It handles the asynchronous nature of the Crazyflie API and turns it into blocking function.
URI of the Crazyflie
After these imports, start the script with:
# URI to the Crazyflie to connect to
uri = uri_helper.uri_from_env(default='radio://0/80/2M/E7E7E7E7E7')
This is the radio uri of the Crazyflie, it can be set by setting the environment variable CFLIB_URI, if not set it uses the default. It should be probably fine but if you do not know what the uri of your Crazyfie is you can check that with an usb cable and looking at the config (here are the instructions).
Main
Write the following in the script:
if __name__ == '__main__':
# Initialize the low-level drivers
cflib.crtp.init_drivers()
with SyncCrazyflie(uri, cf=Crazyflie(rw_cache='./cache')) as scf:
simple_connect()
The syncCrazyflie will create a synchronous Crazyflie instance with the specified link_uri. As you can see we are currently calling an non-existing function, so you will need to make that function first before you run the script.
Function for connecting with the Crazyflie
Start a function above the main function (but below the URI) which you call simple connect:
def simple_connect():
print("Yeah, I'm connected! :D")
time.sleep(3)
print("Now I will disconnect :'(")
Run the script
Make sure your Crazyflie is on and your Crazyradio is connected to your computer, and that the Crazyflie is not connected to anything else (like the cfclient). Now run the script in your terminal:
python3 connect_log_param.py
You are supposed to see the following in the terminal:
The script connected with your Crazyflie, synced and disconnected after a few seconds. You can see that the M4 LED is flashing yellow, which means that the Crazyflie is connected to the script, but as soon as it leaves the simple_connect() function, the LED turns of. The Crazyflie is no longer connected.
Not super exciting stuff yet but it is a great start! It is also a good test if everything is correctly configured on your system.
If you are getting an error, retrace your steps or check if your code matches the entire code underneath here. If everything is peachy, please continue to the next part!
import logging
import time
import cflib.crtp
time.sleep(3)
simple_connect()
Step 2a. Logging (synchronous)
Alright, now taking a step up. We will now add means to read out logging variables to the script!
More imports
Now we need to add imports to the top of the script connect_log_param.py:
from cflib.crazyflie.log import LogConfig
from cflib.crazyflie.syncLogger import SyncLogger
- LogConfig class is a representation of one log configuration that enables logging from the Crazyflie
- The SyncLogger class provides synchronous access to log data from the Crazyflie.
Also add the following underneath URI:
# Only output errors from the logging framework
logging.basicConfig(level=logging.ERROR)
Add logging config
Now we are going to define the logging configuration. So add lg_stab in the __main__ function :
lg_stab = LogConfig(name='Stabilizer', period_in_ms=10)
lg_stab.add_variable('stabilizer.roll', 'float')
lg_stab.add_variable('stabilizer.pitch', 'float')
lg_stab.add_variable('stabilizer.yaw', 'float')
Here you will add the logs variables you would like to read out. If you are unsure how your variable is called, this can be checked by connecting to Crazyflie to the cfclient and look at the log TOC tab. If the variables don’t match, you get a KeyError (more on that later.)
Make the logging function
Use the same connect_log_param.py script, and add the following function above simple_connect() and underneath URI:
def simple_log(scf, logconf):
Notice that now you will need to include the SyncCrazyflie instance (scf) and the logging configuration.
Now the logging instances will be inserted by adding the following after you configured the lg_stab:
with SyncLogger(scf, logconf) as logger:
for log_entry in logger:
timestamp = log_entry[0]
data = log_entry[1]
logconf_name = log_entry[2]
print('[%d][%s]: %s' % (timestamp, logconf_name, data))
break
Test the script:
First change the simple_connect() in main to simple_log(scf, lg_stab). Now run the script (python3 connect_log_param.py) like before.
If everything is fine it should continuously print the logging variables, like this:
[1486704][<cflib.crazyflie.log.LogConfig object at 0x7ffb3384a1d0>]: {'stabilizer.roll': -0.054723262786865234, 'stabilizer.pitch': 0.006269464734941721, 'stabilizer.yaw': -0.008503230288624763}
If you want to continuously receive the messages in the for loop, remove the break. You can stop the script with ctrl+c.
If you are getting errors, check if your script corresponds with the full code:
import logging
import time
import cflib.crtp
data = log_entry[1]
break
# simple_connect()
Step 2b. Logging (Asynchronous)
The logging we have showed you before was in a synchronous manner, so it reads out the logging in the function directly in the loop. Eventhough the SyncLogger does not take much time in general, for application purposes it might be preferred to receive the logging variables separately from this function, in a callback independently of the main loop-rate.
Here we will explain how this asynchronous logging can be set up in the script.
Start a new function
Above def simple_log(..), begin a new function:
def simple_log_async(scf, logconf):
cf = scf.cf
cf.log.add_config(logconf)
Here you add the logging configuration to the logging framework of the Crazyflie. It will check if the log configuration is part of the TOC, which is a list of all the logging variables defined in the Crazyflie. You can test this out by changing one of the lg_stab variables to a completely bogus name like 'not.real'. In this case you would receive the following message:
KeyError: 'Variable not.real not in TOC'
Add a callback function
First we will make the callback function like follows:
def log_stab_callback(timestamp, data, logconf):
print('[%d][%s]: %s' % (timestamp, logconf.name, data))
This callback will be called once the log variables have received it and prints the contents. The callback function is added to the logging framework by adding it to the log config in simple_log_async(..):
logconf.data_received_cb.add_callback(log_stab_callback)
Then the log configuration would need to be started manually, and then stopped after a few seconds:
logconf.start()
time.sleep(5)
logconf.stop()
Run the script
Make sure to replace the simple_log(...) to simple_log_async(...) in the __main__ function. Run the script with python3 connect_log_param.py in a terminal and you should see several messages of the following:
[18101][Stabilizer]: {'stabilizer.roll': -174.58396911621094, 'stabilizer.pitch': 42.82120132446289, 'stabilizer.yaw': 166.29837036132812}
If something went wrong, check if your script corresponds to this:
import logging
import time
import cflib.crtp
cf = scf.cf
logconf.start()
time.sleep(5) # Your possibility to interact with the Crazyflie
logconf.stop()
simple_log_async(scf, lg_stab)
Step 3. Parameters
Next to logging variables, it is possible to read and set parameters settings. That can be done within the cfclient, but here we will look at how we can change the state estimator method in the python script.
First add the group parameter name just above with SyncCrazyflie(... in __main__.
group = "stabilizer"
name = "estimator"
Start the function
Start the following function above def log_stab_callback(...):
def simple_param_async(scf, groupstr, namestr):
cf = scf.cf
full_name = groupstr+ "." +namestr
Add the callback for parameters
In a similar way as in the previous section for the Async logging, we are going to make a callback function for the parameters. Add the callback function above def simple_param_async:
def param_stab_est_callback(name, value):
print('The crazyflie has parameter ' + name + ' set at number: ' + value)
Then add the following to the def simple_param_async(...) function:
cf.param.add_update_callback(group=groupstr, name=namestr,
cb=param_stab_est_callback)
time.sleep(1)
The sleep function is to give the script a bit more time to wait for the Crazyflies response and not lose the connection immediately.
If you would like to test out the script now already, replace simple_log_async(...) with simple_param_async(scf, group, name) and run the script. You can see that it will print out the variable name and value:
The crazyflie has parameter stabilizer.estimator set at number: 1
Set a parameter
Now we will set a variable in a parameter. Add the following to the simple_param_async(...) function:
cf.param.set_value(full_name,2)
If you would run the script now you will also get this message:
The crazyflie has parameter stabilizer.estimator set at number: 2
This means that the Crazyflie has changed the parameter value to 2, which is another methods it uses for state estimation. This can also be done to change the color on the ledring, or to initiate the highlevel commander.
What it can’t do is to set a Read Only (RO) parameter, only Read Write (RW) parameters, which can be checked by the parameter TOC in the CFclient. You can check this by changing the parameter name to group 'cpu' and name flash'. Then you will get the following error:
AttributeError: cpu.flash is read-only!
Finishing and running the script
It is usually good practice to put the parameter setting back to where it came from, since after disconnecting the Crazyflie, the parameter will still be set. Only after physically restarting the Crazyflie the parameter will reset to its default setting as defined in the firmware.
So finish the simple_param_async(...) function by adding the next few lines:
cf.param.set_value(full_name,1)
time.sleep(1)
Make sure the right function is in __main__. Check if your script corresponds with the code:
import logging
import time
import cflib.crtp
cf = scf.cf
full_name = groupstr + '.' + namestr
time.sleep(1)
cf.param.set_value(full_name, 2)
time.sleep(1)
cf.param.set_value(full_name, 1)
time.sleep(1)
group = 'stabilizer'
name = 'estimator'
Run the script with python3 connect_log_param.py in a terminal and you should see the following:
You’re done! The full code of this tutorial can be found in the example/step-by-step/ folder.
What’s next?
Now you know how to connect to the Crazyflie and how to retrieve the parameters and logging variables through a python script. The next step is to make the Crazyflie fly by giving it setpoints which is one step closer to making your own application!
Go to the next tutorial about the motion commander.
