The Camera Deck sends startup and runtime console output to the Crazyflie over
UART. Clients can discover and enable it as the deck:bcCam source of the
CRTP console. During normal startup, the source becomes
available after the Crazyflie passes its self-tests and starts the deck
service.
The bcCam driver enumerates the Camera Deck’s Common Link service catalog
and binds a compatible bitcraze.console service. It uses the advertised
service handle rather than assuming a fixed handle or catalog position.
When a client enables deck:bcCam, the Crazyflie grants one Common Link
receive slot for Console output. It forwards received bytes into the CRTP
transmit queue, splitting a Common Link frame across CRTP packets when needed.
It grants another slot only after the previous frame has been queued. The
Console slot is independent of the Control service slot, so a stalled Control
probe does not prevent Console output.
If the CRTP transmit queue is full, the Crazyflie keeps the accepted frame and stops granting Console receive slots. Later output remains in the Camera Deck’s spool, subject to the deck’s storage limit. A radio activity timeout does not clear Console packets already queued on the Crazyflie. Queue acceptance does not confirm delivery to a client.
Accepted frames remain pending while the source is disabled and can be forwarded after it is enabled again. They also survive a Camera Deck reboot or a link fault, so output sent just before a reboot is not lost on the Crazyflie.
The UART link has no retransmission, so any lost or corrupted byte ends the
current link session. This includes a UART overrun on the Crazyflie. The
Crazyflie then establishes a new session without resetting the deck, so the
deck and its camera stream keep running. The frame being received at that point
is lost. If deck:bcCam is enabled, clients receive [console data lost] in
the output, which can also appear when the lost frame was not a Console frame.
The bcCam.uartErrors and bcCam.faults log variables count these events.
There is no limit on the number of new sessions. While waiting for the deck to
accept a new session, the Crazyflie sends the request again every 500 ms.
The Crazyflie resets the deck when a session cannot be recovered this way:
- The deck breaks the link protocol.
- The UART link is not active within 3 seconds.
Once the link is active, the startup-recovery watchdog does not reset the deck, whatever the state of the services above the link, and enabling the console has no effect on it. If startup still has not completed 3 seconds after the link came up, for example because the Control probe stalled, the Crazyflie reports it once on its own console. The deck’s console output then remains available to explain the stall.
