Autonomous flight
Take off
When flying autonomously, it’s important to get a few things right before take-off. This applies both to apps running in the Crazyflie and to remote clients such as cflib, cflib2 and crazyflie-lib-rs. These are the minimum steps required to get off the ground, they are not a complete pre-flight checklist.
This page collects the steps required in the order they must happen.
1. Wait for the system to start
Firmware apps: The firmware calls appMain() once the system task has started, but this does not mean that the Crazyflie is ready to fly. Estimators and decks may still be settling. Many of the examples start with a vTaskDelay(M2T(2000)), which is only a simple way to let the system get going before printing or acting. It is not a guarantee of anything, and for flight you should wait for the conditions below.
Remote clients: The radio link is enabled before the decks are initialized, so a client can technically connect while the system is still booting. In practice, setting up the connection normally takes longer than the boot.
2. Wait for the position estimate to converge
If the Crazyflie takes off before the position estimate has converged, the position control acts on a bad estimate and the Crazyflie may fly off or crash.
The supervisor does not check estimator convergence. It is up to the app or client to wait for it.
In cflib, reset_estimator() in cflib.utils.reset_estimator resets the estimator and then waits for the variances to settle.
3. Arm the system
The supervisor must be armed before the motors are allowed to run. This is not needed if auto arming is enabled. Auto arming is the default on the brushed Crazyflie 2.1(+).
Platforms that require arming, such as the Crazyflie 2.1 Brushless and Bolt, need an explicit arming request.
Apps arm the system by calling supervisorRequestArming(true), remote clients by sending a CRTP arming message. In cflib this is cf.supervisor.send_arming_request(True), see for instance examples/step-by-step/sbs_motion_commander.py.
4. Take off before the preflight timeout
Once armed, the Crazyflie must take off within the preflight timeout. If it does not, the supervisor leaves the Ready to fly state, goes back to Pre flight checks passed and disarms. The system must then be armed again.
The timeout is set by the supervisor.prefltTimeout parameter, in milliseconds. The default is 30000 (30 s), defined by PREFLIGHT_TIMEOUT_MS in platform_defaults.h.
Examples
Basic examples that follow these steps can be found in each repository:
For more complete examples, see the crazyflie-demos repository.
