The OneWire (OW) memory contained in all Crazyflie 2.x decks is used to detect the boards connected in order to:
- Decide if it is safe to start the system.
- When the system is started, initialize the required drivers for the deck installed.
- The header is 7 bytes long and contains the identity of the board encoded in VID/PID (Vendor ID and Product ID) as well as a bitfield describing the pins the deck is driving (to avoid conflict).
- The key/value area is extendable and contains more information like the deck name, board revision and driver-specific information (ie. for configuration or calibration for example).
Content
1. Header 1 Byte 0xEB
2. UsedPins 4 Bytes
3. VID 1 Byte
4. PID 1 Byte
5. crc 1 Byte CRC32[0] (LSB byte) from 1 to 4.
6. Version 1Byte, 0 for now
7. DataLength 1 Byte (255 max data length…)
8. key/value data <DataLength> bytes
9. crc 1 Byte CRC32[0] (LSB byte) from 6 to 8
- The header area is from 1 to 5.
- The key/value area is from 6 do 9
Header
| Drive | PC11 | PC10 | PB7 | PB6 | PB8 | PB5 | PB4 | PC12 | PA2 | PA3 | PA5 | PA6 | PA7 | P0.11 | P0.12 | P0.08 |
| Low | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 |
| High | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 | 26 | 27 | 28 | 29 | 31 | 31 |
For example is a deck has a GPS that has its UART TX on PC11 (push-pull, drives high and low), the UsedPins value will be (1<<0) | (1<<16) = 0x00010001. As another example is a deck has an I2C sensor on PB6,PB7 (Open collector, only drives low), the UsedPins value is then: (1<<2) | (1<<3) = 0x0000000C
Key/value area
Elements have this format:
| Id | 1Byte |
| length | 1Byte |
| data | <length> Bytes |
| Element | Element_id | Data type | Note |
| boardName | 1 | string | Short. Starts by “bc” for Bitcraze boards |
| revision | 2 | string | |
| customData | 3 | binary | Data understood by the deck driver |
Example
0000000: eb 00 00 00 00 bc 01 44 00 0e 01 09 62 63 4c 65 .......D....bcLe
0000010: 64 52 69 6e 67 02 01 62 55 dRing..bU
Content:
"header": {
"usedPin": 0,
"vid": 188,
"pid": 1
"data": {
"boardName": "bcLedRing",
"revision": "b"
Element IDs and types (DTD):
"boardName": {
"type": "string",
"id": 1
"revision": {
"type": "string",
"id": 2
"customData": {
"type": "binary",
"id": 3
