Introduction
App entry-point
When compiling the Crazyflie with CONFIG_APP_ENABLE=y the firmware will call a function void appMain() from a task after the startup sequence has completed. This function should not return.
If you want more control, you can define a function void appInit(). appInit() will be called by the firmware during initialization, no task will be created and so appMain() will not be automatically called.
This function must return to allow the Crazyflie initialization sequence to continue.
The following Makefile and out-of-tree config can be used to build an app.
For more information see the documentation for out-of-tree build.
CRAZYFLIE_BASE := ../..
Where app-config is:
CONFIG_APP_ENABLE=y
CONFIG_APP_PRIORITY=0
CONFIG_APP_STACKSIZE=300
Your source file should be defined in a Kbuild file, like:
obj-y += your-app.o
You can look at the applications in the examples/ folder of the firmware repository.
Configuring the app layer
The app layer can be configured with Kbuild. Default configurations can be loaded by running make cf2_defconfig in the app directory. Terminal based user interfaces (‘menuconfig’, ‘nconfig’, ‘gconfig’, ‘xconfig’) can be used to configure the app layer by e.g. running make menuconfig in the app directory. Note that if there are any conflicting settings, the values defined in app-config will take priority.
Building the app layer
In order to build the app layer, go to the root folder of the app example and run:
make clean
make
or with the toolbelt, from the crazyflie-firmware root:
tb make_app examples/app_hello_world/ clean
tb make_app examples/app_hello_world/ -j8
Then flash the resulting bin on your crazyflie according to the flashing instructions. Make sure to point to the right build binary.
Note: If you are using macOS you may encounter errors when trying to build your app, such as:
readlink: illegal option -- m sed: invalid command code . cp: illegal option -- TThis happens because the app-layer build expects the GNU versions of
readlink,sedandcp. To fix the errors, install and use the GNU utilities:brew install coreutils gnu-sed
Internal log and param system
For the app-layer, it would be good to have access to log and/or parameter values and to set parameter values. This way, your app will be able to read out sensor data or to switch controller/estimator on air. To check out these functions, look at src/modules/interface/log.h or .../param.h for the internal access functions. There is also an example to be found in /examples/app_internal_param_log/.
LED sequences
It is possible to run LED sequences from the app layer to control the four LEDs on the Crazyflie and provide runtime information to the user. See the src/hal/interface/ledseq.h file for more information.
The Appchannel API allows to communicate using radio packets with an app. The packets can contain anything of a size up to 30 bytes, the protocol is defined by the app.
For more information about the API see the header file src/modules/interface/app_channel.h.
An example of how to use the app channel is in examples/app_appchannel_test/
Examples
