CRTP Sniffer Tab
The CRTP sniffer tab captures and displays all CRTP (Crazyflie Real-time Transfer Protocol) packets sent to and received from the Crazyflie in real time. It is useful for debugging communication between the client and the drone.
cfclient CRTP sniffer tab
  1. Fields
    • ms: Timestamp in milliseconds since the sniffer was enabled
    • Direction: IN for packets received from the Crazyflie, OUT for packets sent to it
    • Port/Chan: The CRTP port and channel of the packet, formatted as port/channel
    • Data: The packet payload as a hexadecimal string
  2. Controls
    • Enable: Check to start capturing packets. Uncheck to pause capture. Heartbeat packets are automatically filtered out to reduce noise.
    • Clear: Removes all packets from the display and clears the internal buffer.
    • Save: Writes all captured packets to a CSV file.
The saved file is written to the logdata folder in the client configuration directory and is always named shark_data.csv, overwriting any previous save. To find your configuration directory, click Settings / Open config folder.
Example of saved data:
1042, OUT, 0/0, 01ff
1103, IN, 0/0, 00
1245, OUT, 5/0, 0300000000
