Reproducibility and Continuity in Aerial Robotics
Inheriting an experiment is often harder than building one. A PhD student graduates. A postdoc moves on. A sensor gets discontinued, and six months later, reproducing the earlier work means reconstructing a software environment, rebuilding a hardware setup, and re-deriving assumptions that were never written down anywhere. The paper is still there, but the experiment usually isn’t.
Reproducibility is normally discussed in terms of published results: can someone else get the same numbers from the same method, but in practice, most labs run into a different problem first, and it’s a more mundane one. Continuity. A new student needs to take over a project without starting from scratch, or a collaborating lab needs to replicate a setup without rebuilding the surrounding infrastructure. Then the experiment itself needs room to evolve without dragging everything underneath it into a rewrite.
Preserving context, not just code
Code and datasets are easier to share now than they’ve ever been, and that’s real progress. But a repository is not the same thing as an experiment. What a new student actually inherits is a pile of things that rarely make it into a GitHub repo: hardware configurations, positioning system calibration, flight scripts tuned by trial and error, a specific combination of dependency versions that happens to work, and a layer of tacit lab knowledge. That last part is usually the stuff someone would tell you in five minutes at the whiteboard. It never gets written down.
The problem compounds as the work moves forward. A sensor gets replaced. ROS moves to a new version. New questions branch off from the original project, and each one drags a little more infrastructure along with it.
A stable platform doesn’t solve reproducibility. Poorly documented assumptions are still poorly documented assumptions. But it can remove one source of uncertainty: the platform underneath the experiment hasn’t become something completely different. That matters when the next researcher needs to understand what was built before they can build on it.
Compatibility over time has research value
Infrastructure that survives across multiple projects tends to become more useful with time. A platform a lab can keep using across student cohorts and research directions accumulates knowledge around it: working configurations, scripts, extensions, troubleshooting experience and, eventually, people who know how the pieces fit together.
That’s one of the less obvious benefits of the Crazyflie® ecosystem. The platform has changed considerably over the years, as it should. Hardware has evolved, APIs have developed and tools have come and gone. But much of the underlying architecture and the way the pieces relate to each other remains recognizable.
That technical lineage matters. Someone returning to Crazyflie research from five or even ten years ago won’t find exactly the same system, but neither will they find an unrelated one. The communication model, firmware architecture, development tools and approach to hardware extensions have evolved incrementally rather than being repeatedly replaced.
It means older work can remain useful as a starting point rather than simply becoming a historical reference.
Reproducibility between people, not just between runs
Reproducing an experimental result and continuing someone else’s research aren’t quite the same problem. But they share much of the same infrastructure.
Robotics has irreducible uncertainty in it, and no platform removes that. What a well-designed, long-lived platform can do is lower the cost of understanding, reconstructing and extending previous work.
It’s a less visible kind of value than a benchmark result. But in labs where a project outlives the people who started it, that continuity is often what makes cumulative research possible at all
Did you know?
  • Today’s firmware still supports Crazyflie 2.0 (apart from certin recent features)
  • You can take over someone else’s sysid work. If you would build your own platform you would need to redo that. (When the Crazyflie 2.1 Brushless came out immediately people rushed to get out their sys id papers. There’s multiple out there now already.)
  • CRTP (the radio protocol) has been stable for over a decade.
  • Param/log TOC lets the Crazyflie tell a client at runtime what parameters/logs are available. This (among other things) allows years-old scripts to maintain compatibility with newer firmwares and even across different platforms in the ecosystem.
  • The firmware reports its own firmware revision so user logs can include this.
  • The deck port (the pins) are unchanged. The deck working on your Crazyflie 2.0 works on your Crazyflie 2.1 Brushless.
  • Out-of-tree extension points; allows writing apps controllers and estimators for the community to separate their work from our firmware version.
