LED hack
When I was shopping for some ink-cartridge at this Swedish accessory store named Kjell&Co I also bought one of these 12V LED lamps. I didn’t buy it to actually use it instead I bought it to have a look inside. I cracked it open when I came home and found, not so surprisingly,  a lot of LEDs and a step up converter with a current sensing mode. Since it was made for 12V AC I removed the rectifier bridge and a large cap to get it as light as possible. Testing it with a power supply reviled that it worked all the way down to 2.2V and at 3.7V it consumed about 0.5A. A bit to much for the Crazyflie so I doubled the current sensor resistors to get it down to 0.25A. Some soldering and some double sided foam tape and we suddenly have  a pretty bright lamp hooked up to the Crazyflie. Now we have a search&rescue device :-) or maybe just an UFO…
Let’s not forget the sensor poll. It’s a very close encounter with 55% wanting the extra sensors. We will keep the poll open until next week to see if it gets any clearer.
3 comments on “LED hack”
  • A flying flashlight !! This is an awesome hack .. Unbelievable how much light those led things give on such a low power :-) Liked it a lot :-)
  • it would be nice to have some swiching pads so you can remotely turn on and off attached things like this lamp or a flycam… ;)
Comments are closed.
