Updated autonomous flight using OpenCV and Kalman filter
At Bitcraze we have some history with trying to fly our Crazyflie autonomously. The most recent step is the Loco Positioning System that allows us, and you, to fly in a full room. The Loco Positioning system has boosted development of advanced algorithms for onboard position estimation and control.
Our earlier attempts where mostly based on different kinds of cameras, either a 3D camera like Kinect or regular webcams. Though, at that point, we only had the camera for position estimation and where doing the position control on the PC and not onboard the Crazyflie. This has the disadvantage to be brittle and requires a very high quality positioning from the camera: any frame where we loose the Crazyflie has a huge impact on the control behavior since the position controller relies exclusively on the camera detection.
With the Kalman filter and onboard position controller, the Crazyflie can now handle lost position information for at least a couple of seconds without big problems. This has the potential of making webcam-based position detector much more robust!
To test this theory we have grabbed the 2 years old crazyflie-ar-detector from the dawer github, updated it to OpenCV 3.2.0, and fed the position output to the Crazyflie 2.0 external position port. The crazyflie-ar-detector program is using ZeroMQ to communicate position and so we made a simple external position tab for the Crazyflie Client that receives position from ZeroMQ and sends it to the connected Crazyflie.
Using the new position-hold mode recently introduced in the client we can test and fly the Crazyflie under the webcam. We have taken a short video to show the performance. The result is promising and we will continue to play with ways to fly the Crazyflie autonomously.
